AutoCAD Civil 3D General
rwhip12
Message 1 of 8 (96 Views)
C3D 2011 not loading
96 Views, 7 Replies
05-03-2012 02:17 PM
When I start C3D 2011, it starts to load and then freezes once it gets to loading AEC Point Cloud and the acad.dwt.  It started to do this once I set Hardware Accelerator to be on. It will load about 40% and then totally hose my entire computer.  And of course now it won't load so I can't shut the setting off. Anyone seen this?
TIA
Alfred.NESWADBA
Message 2 of 8 (93 Views)
Re: C3D 2011 not loading
05-03-2012 03:11 PM in reply to: rwhip12
I don't understand how AutoCAD is on the way to start, the acad.dwt is not loaded but access to a point-cloud is active/is to be loaded.
May be this is not interesting at the moment. Open Windows-TaskManager, look if there is a process called like WsCommCntrl*, if so and if that is using processor power ==> kill it, and then look back to AutoCAD how it works now.
- alfred -
Alfred NESWADBA
rwhip12
Message 3 of 8 (80 Views)
05-04-2012 05:47 AM in reply to: Alfred.NESWADBA
The problem is....when the program freezes it completely freezes my computer.  Task manager will not open, crosshairs are frozen.  I actually have to turn the computer off with the start button.
Alfred.NESWADBA
Message 4 of 8 (77 Views)
05-04-2012 05:51 AM in reply to: rwhip12
>> [...] it completely freezes my computer
extremly unusual that the computer freezes at all, or it's some hardware or hardware-driver issue.
So what sysinfos do you have (processor, graphiccard + gc-memory, main memory, operating system).
Did Civil3D run already and the problems came up later or have you just installed it?
What happens if you login with another user-account to your Windows and try Civil3D again?
- alfred -
Alfred NESWADBA
antoniovinci
Message 5 of 8 (74 Views)
05-04-2012 06:38 AM in reply to: Alfred.NESWADBA
1] restart the machine in Safe Mode
2] log in as admin
3] first, run Task Manager, and set its visibility as "Always on top"
4] after, run Autocad
Now you should be able to switch off every undesidered setting, and eventually kill the acad.exe process.
Jeff_M
Message 6 of 8 (71 Views)
05-04-2012 06:56 AM in reply to: rwhip12
You can turn off the Hardware Acceleration at startup by editing the Target in the shortcut used to start C3D. It should look like this in the Properties for the shortcut:
"C:\Program Files\Autodesk\AutoCAD Civil 3D 2012\acad.exe" /ld "C:\Program Files\Autodesk\AutoCAD Civil 3D 2012\AecBase.dbx" /p "<<C3D_Imperial>>"
At the end of this, add a space then /nohardware
This will disable HA for the session, but will not alter the setting in th eregistry. So be sure to turn it off in the settings. Once the settings are setyou can remove the /nohardware switch.
rwhip12
Message 7 of 8 (67 Views)
05-04-2012 07:06 AM in reply to: Jeff_M
ooooh.. going to try this right now
rwhip12
Message 8 of 8 (62 Views)
05-04-2012 07:32 AM in reply to: Jeff_M
Jeff
awesome!  it worked.  I can now get back into the program and worked.  :smileyhappy:
Rick
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
