Guido / Matt,
Excellent observations. It is also great Autodesk moved Autocad to the 64-bit dimension. However, the central idea of a 64-bit application is to max the use of the hardware. I had big expectations from the 64-bit version of Autocad/Civil 3D, but ran into some disappointments when I loaded it in my i7, 8gig mem laptop. Civil 3d runs slow on a basic rendering I created. I ran a simultaneous test with the same 3D model on a 32-bit system Intel Core 2Duo. To my dismay my super fast laptop took twice the time to render the model compared to the Core2. For a moment I thought my system was faulty until I came across your comments. Now I start to comprehend the reason behind the difference in speed.
Thanks for sheding light on the issue. I am sure Autodesk wil fix the issue with the upcoming versions (I hope it is soon).
Harold
If I could ask.... what is the model number of the Core 2 Duo (really interested in the clock speed without turbo) and also which i7 core did you do the test on? Trying to figure out if it's better to run a system that has more base clock speed and with 2 cores vs a lower clock speed with 4 cores (specifically for rendering).
Just can't get a straight answer on this question and your test was the first that I could find that would do this type of comparison (however, I realize that one test was done on 32bit and the other 64bit). It seems the base clock speed is REALLY important, even for rendering. The general concensus seems to be that more cores is better for rendering; however, more cores means less base clock speed on i7-600 and i7-700 series cores; from your test, a core 2 duo with I'm assuming a higher base clock speed worked better...
