James,
You da man!
-Rob
"James Wedding" wrote in message
news:4924617@discussion.autodesk.com...
If you do any subdivision work, you've already run into the fact that
Corridor surfaces do not link up to the C3D surfaces that they export.
Here's a work around that will allow you to include a corridor surface as
part of your proposed surface, and have it update as needed.
1. Create your corridor and generate a surface as you'd like it.
2. Export that out to a C3D surface.
3. DO NOT edit this surface. You want this to be the exact surface that was
exported. You'll notice this surface is built by nothing but a series of
"Add Point..." edits, so don't even go looking for the breaklines.
4. Export the C3D surface to an XML file. Don't export anything BUT the
surface! Call it Corridor.XML for simplicity.
5. Delete the corridor's C3D surface.
6. Go to General and Import LandXML and import Corridor.XML into a new
surface.
7. Rename the imported surface, i.e. PG. Notice that PG is made of an Import
XML operation and a snapshot. That's it!
8. Add to that surface using breaklines, feature lines, points, pastes, etc.
9. Build your surface. You now have a surface built from corridor, points,
pads, etc.
10. If your corridor changes, simply reexport the corridor's surface to
C3D, and reexport that surface to the XML file. Rename the XML file that's
there, and use the same name. It's important!
11. Rebuild your PG surface. Because the first step in the build operation
of the PG surface is to import the Corridor.XML file, you will now have an
updated corridor underneath it all, and your points, pads, breaklines,
borders etc will all still be in place, in the correct build order.
Thanks a TON to the Desker that helped me out on this. I don't want to name
him since he'll be hammered with e-mails for more help.
Hope this helps some of you, and I hope to see you in Orlando at AU.
James Wedding, P.E.
Technology Manager &
Associate
Jones & Boyd, Inc.
Dallas, TX
XP/2 on P4-3.4/1G
LDT 2006 & C3D2006/SP1
