Civil 3D Forum
Bugging text in 2015
11 REPLIES 11
Message 1 of 12
SSato54
883 Views, 11 Replies
I recently installed C3d 2015 and came across some problems with my text.  The drawing is showing these lines between different portions of text and will move/readjust when panning/zooming. It doesnt seem like its tied to a specific font type either...C3D 2015 - txt bug.jpgIt seems as if it only occurs with existing drawings and civil 3d 2015 (all other C3D versions work properly).  New drawings dont show these stray lines between text.  Has anyone had this problem? know a solution?
11 REPLIES 11
Message 2 of 12
Cadguru42
in reply to: SSato54
I haven't seen this issue. Are they C3D labels? Are they MTEXT objects or MLEADERS?
C3D 2022-2024
Windows 10 Pro
32GB RAM
Message 3 of 12
SSato54
in reply to: Cadguru42
The text in this drawing is dtext, however, mtext seems to bug out as well when added to the drawing. These stray lines basically connect to any text in the drawing (xref, block refs, dtext, mtext...)
Message 4 of 12
SSato54
Okay, so here's an update on the problem. I can add new text to the drawing as previously mentioned and the stray lines will start showing up, however, the lines will disappear when i delete all the old text (xrefs, blocks, everything...) from the drawing. this basically means i need to recreate the entire drawing to get rid of this problem which likely wont happen. Anyone have any ideas why existing text within the drawing might cause these stray lines to show up?
Message 5 of 12
Jeff_M
Can you post the dwg file? If not here due to size, perhaps Dropbox?
Jeff_M, also a frequent Swamper
Message 6 of 12
SSato54
in reply to: Jeff_M
Attached is a portion of the topo. Again, this file opens fine in C3D 2014, but gives me these lines in C3D 2015. I'm starting to think its just a bad install?
Message 7 of 12
SSato54
sorry, had a problem attaching the file due to our restricted internet. should be attached now.
Message 8 of 12
AllenJessup
SSato54 wrote:this basically means i need to recreate the entire drawing to get rid of this problem which likely wont happen.
Rather then recreating everything. Why don't you try to Wblock the text out, insert it in a fresh template and see if that clears it up. If not. Try a DXFout and In.
Allen
Allen Jessup
CAD Manager - Designer
Message 9 of 12
Jeff_M
Not sure, but since I am not seeing any issues with your drawing in 2015 I can only guess that it is due to the Bigfont assigned to your text styles (which I do not have so another was used in it's place.) Try removing the use of Bigfont, or changing the font used, for the S-X styles and see if that clears it up.
Message 10 of 12
Did you ever solve this problem?  I'm having the same issue.
Message 11 of 12
I turned hardware acceleration off, and it seems to have fixed the problem.
Message 12 of 12
SSato54
That fixed it alright.  I wasnt able to figure it out after playing with the fonts, so i reverted back to 2014. Thanks for the reply!
Rail Community
