Distinguished Contributor
Rainman1
Message 1 of 18 (355 Views)
Breakline Issue
355 Views, 17 Replies
10-16-2013 10:22 AM
Please see attachment. I have highlighted my TIN and for some reason when C3D triangulates my surface it is not incuding the complete polyline. You can see some magenta, blue and yellow lines that are not part of the surface. Portions of the polyline are not included in the TIN but some portions are. The lines are 2d and 3d polylines.  I have tried adding vertices to the lines, created feature lines with them, converted the 2D polylines to 3D polylines, create points along the polyline.....tried adding them as breaklines, lines, points, etc. but none of these procedures will add the linework to my surface??? When it does this it leaves our model incomplete.
troma
Message 2 of 18 (352 Views)
Re: Breakline Issue
10-16-2013 10:25 AM in reply to: Rainman1
Do you have a default weeding set for when you're adding breaklines to the surface?
Credit where credit is due! Give kudos or accept as solution whenever you can.
Rainman1
Message 3 of 18 (349 Views)
Re: Breakline Issue
10-16-2013 10:31 AM in reply to: troma
I have never touched the "Weeding factors" setting. Just played around with it a bit, changed the setting (default 15)....tried "0", 2, 15. It will add a small portion of the line but still not including the complete line?????
troma
Message 4 of 18 (341 Views)
Re: Breakline Issue
10-16-2013 10:44 AM in reply to: Rainman1
I would've thought zero would work.
What happens if you turn it off altogether?
Rainman1
Message 5 of 18 (338 Views)
Re: Breakline Issue
10-16-2013 10:48 AM in reply to: troma
I didn't use it at all in my initial build of the surface and you see what the results are in the attachment.
troma
Message 6 of 18 (321 Views)
Re: Breakline Issue
10-16-2013 11:39 AM in reply to: Rainman1
You're sure it was switched off? Or could it have been on & you didn't notice it?
Rainman1
Message 7 of 18 (304 Views)
Re: Breakline Issue
10-16-2013 11:51 AM in reply to: troma
When you go to add your breaklines the dialogue box pops up and you have to put a check mark in "Weeding factors" to enable and use it.
troma
Message 8 of 18 (298 Views)
Re: Breakline Issue
10-16-2013 12:17 PM in reply to: Rainman1
I believe that depends on how your command default settings have been set up. But if that's how it is for you it indicates that this probably isn't the problem. Time to look elsewhere...I can't think where though.
Rainman1
Message 9 of 18 (295 Views)
Re: Breakline Issue
10-16-2013 12:21 PM in reply to: troma
Thanks for your input. I have put in a service ticket with our Autodesk Support, hopefully they can find a solution!
david.zavislan
Message 10 of 18 (262 Views)
Re: Breakline Issue
10-17-2013 08:41 AM in reply to: Rainman1
When adding breakline data to the surface, reduce the value of the curve supplementing factor to add more data along the arc segments.  I use 0.05-0.1.
You may also have crossing breaklines that are being ignored.  In the surface properties command, on the Definition tab, change the Allow crossing breaklines property to Yes.
David Zavislan, P.E. | Wood Rodgers, Inc.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
