AutoCAD Civil 3D General
*Brian Hailey
Message 1 of 3 (48 Views)
Breaking Breaklines
48 Views, 2 Replies
02-18-2004 07:29 AM
Hello everyone, I've noticed that if you break a breakline into two seperate breaklines, all information from that line gets removed from the surface. Is this by design? If so, I don't like it. I would much rather have original line removed from the surface and the two new lines added to it. Brian
*Daniel Philbrick
Message 2 of 3 (48 Views)
Re: Breaking Breaklines
02-20-2004 05:04 AM in reply to: *Brian Hailey
Brian, If you use the AutoCAD break command on a breakline, a portion of the original breakline does remain as a breakline, and the second part is removed from the surface definition. Your suggestion of having both segments of the breaklines remain as part of the surface definition is probably better (and expected) behavior. Thanks for the input. Daniel Philbrick ISD Civil Development "Brian Hailey" wrote in message news:403384cb$1_3@newsprd01... > Hello everyone, > > I've noticed that if you break a breakline into two seperate breaklines, all > information from that line gets removed from the surface. Is this by > design? If so, I don't like it. I would much rather have original line > removed from the surface and the two new lines added to it. > > Brian > >
*Brian Hailey
Message 3 of 3 (48 Views)
11-08-2004 01:41 PM in reply to: *Brian Hailey
Hi Dan, I noticed this was not implemented in 2005. I think this is a very important aspect of the program that needs to be addressed. Brian "Daniel Philbrick" wrote in message news:403605ea$1_2@newsprd01... > Brian, > > If you use the AutoCAD break command on a breakline, a portion of the > original breakline does remain as a breakline, and the second part is > removed from the surface definition. Your suggestion of having both > segments of the breaklines remain as part of the surface definition is > probably better (and expected) behavior. > > Thanks for the input. > > Daniel Philbrick > ISD Civil Development > > > "Brian Hailey" wrote in message > news:403384cb$1_3@newsprd01... >> Hello everyone, >> >> I've noticed that if you break a breakline into two seperate breaklines, > all >> information from that line gets removed from the surface. Is this by >> design? If so, I don't like it. I would much rather have original line >> removed from the surface and the two new lines added to it. >> >> Brian >> >> > >
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
