Need help. Out of the blue all 6 users started to have their cursors blink or alternate from the windows 7 thinking circle to the cursor. It's just in Civil3D. At first I thought it could be a windows update issue but I have used a system restore to go back 2 weeks when it wasn't happening and it still does it. I removed all customization and setup and it doesn't help. I've checked the 3dconfig with multiple settings on or off, I turned off all palettes to solid. I made sure all video card drivers are updated and Autodesk certifed. The problem seems to be worsened by palettes being open and it seems to get worse the longer your in the drawing. I'm currently in the process of working from clean install (uninstalled c3d all the way registry and all, and reinstalled) back to the settings I had before. I first did an out of the box install, then sp1, then hot fixes, then paths to the server for plot styles and font directories. So far it hasn't come back. Anyone else having any issues like this? It's almost like it's processing in the background somthing.
I have that problem happen if I use "_AeccStationTrackerAll" and stay in a file for a long period. However it goes away once I close C3D and reopen. Doesn't necessarily sound like the same problem. Does it happen regardless of the files open? Are you all working in the same project?
No matter which file. Seems to be somewhat effected by the complexity of the drawing or number of drawing you have open. May just upgrade to 2014 to see if it goes away.
