Civil 3D Forum
Blank Profile View
12 REPLIES 12
Message 1 of 13
Joyfer
2224 Views, 12 Replies
Blank Profile View
I'm a brand new user so hopefully this is an easy question for some of you.
Given a drawing of 3d polyline topo data i was asked to create a profile view.
I got out a training book and simply followed the instructions given to create a profile view from a surface.
The profile view is blank.
Attached is a screan shot of what I am dealing with.
Thank you all!
Joy
12 REPLIES 12
Message 2 of 13
troma
in reply to: Joyfer
Did you create a surface?
Mark Green
Working on Civil 3D in Canada
Message 3 of 13
Joyfer
in reply to: troma
Yes.
Message 4 of 13
troma
in reply to: Joyfer
Check the profile style.
Check all layers on & thawed.
Check the stations & elevations set for the profile view: if you set them yourself you could be out of range of the surface.
Close program & reopen.
Just a few thoughts.
Mark Green
Message 5 of 13
Joyfer
in reply to: troma
Thanks I appreciate that unfortunately I'm still at a loss, any further ideas would be hugely appreciated.
What i did do is create a standard surface and allignment to use. I used the create profile from surface comand and stuck to the standard settings. I have been messing around with the settings for quite a while.
Message 6 of 13
awood
in reply to: Joyfer
Did you add the surface to the profile list?
Message 7 of 13
BrianHailey
in reply to: Joyfer
Go to your profile view properties and check to see if there are any profiles that can be displayed. If you aren't sure how to do it, click HERE.
If you don't have any profiles listed, you need to create a surface profile. HERE is how to do that.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 8 of 13
Joyfer
in reply to: BrianHailey
Thanks guys,
I do have surfaces listed in the profiles tab of the view properties.
The elivation I'm using is accurate.
Please let me know if any other ideas come to mind.
Message 9 of 13
sboon
in reply to: Joyfer
Post the drawing as an attachment, so that others can take a look at it.
Steve
Expert Elite Alumnus
Message 10 of 13
Joyfer
in reply to: sboon
Attached is the drawing. Thanks all.
Message 11 of 13
Jeff_M
in reply to: Joyfer
Your surfaces have nothing defining them and they have been moved, twice. Remove the two moves, add the lines/polylines as breaklines and they show up fine:
Jeff_M, also a frequent Swamper
Message 12 of 13
Joyfer
in reply to: Jeff_M
You are awesome, you all are! I tried to figure out how to "remove moves" but I don't know?
Message 13 of 13
Jeff_M
in reply to: Joyfer
Go to the Surface Properties and :
If you uncheck an item the surface will not use it when rebuilt. Once you verify that it's not needed you can right click and remove it.
If you find a response which answers your question, please be sure to accept the actual post which helped you as the solution. This will help future searchers quickly find answers to their own questions. Thanks!
Rail Community
