Has anyone had issues with Bing bringing imagery in which is not in the correct place. I have set up several drawings today using NAD83 Ohio State Planes, North Zone, US Foot. 7 out of the 8 are correct, one is no where near where it should be (verfied using Google Earth and a point file)?
Thanks in advance for any assistance.
Are you bringing them in with mapiinsert, or project base jump?
dmartin wrote:Are you bringing them in with mapiinsert?
As far as I know, the _MAPIINSERT command doesn't support online imagery: maybe did you mean _MAPCONNECT..?
Or are you using C3D 2014's built-in Bing Map feature?
Yes Matt, the built in feature. I have been using for a couple months now with only 2 issues, the one described above, it has happened twice. I was using the feature all day yesterday, same co-ordinate system, different drawings and this only happened on one of them.
neilyj (No connection with Autodesk other than using the products in the real world)
Thanks for reply, removed co-ordinate system saved and exited drawing, got back in reset co-ordinates, same issue..no luck, but thanks
I Tried using it yesterday.
Set my Coordinates (via toolspace, ran it and it stated no connection to 360 or internet or I have chosen not to use feature.
Logged into 360, ran again same message. Tried clicking display map button but nothing happened, searched help but no answers there.
I know it seems a bit far fetched but what we need is some kind of application which will import mapping & surface data directly from google earth
M
... we need is some kind of application which will import mapping & surface data directly from google earth ...
If you were to consider third party software, take a look at MapWorks Base. It contains a Web Elevation function that will place points (from USGS/USA or GE/GLOBAL) in a grid pattern by simply selecting a desired window and interval.
Dialog Example: http://www.dotsoft.com/images/mwprjgeielev.png
Hi Terry,
Does this function work with the National Map Viewer servers from the USGS National Geospatial Program (NGP)?
Here is the background info on the USGS option.
http://gisdata.usgs.gov/xmlwebservices2/elevation_service.asmx
Does this routine allow the user to move the images or set the drawing location, with drawings that have data that is on local coordinate systems, by choosing two common point locations like the GEOMAP routine?
Even though this thread's subject is about images, I responded to a sentence about:
... import mapping & surface data directly from google earth ...
So I was talking about the ability to place points (that can be modeled) directly from web services in a grid pattern.
Ok thanks Terry.
Do you happen have anything that will work with images the way GEOMAP does, that can easily adjust either the drawing location or the image, with a Bing or Google image that we can end up printing?
Having worked for an aerial mapping company about 40 years ago. Spending a lot of time both setting out aerial control networks and operating a pair of Wild RC8s in the back of a Beach 99. Let me tell you why your images from Google, Bing ect will not collate.
The images that are available are considered resonance grade images( though they appear to be decimeter resolution) they are geo rectified in WGS84LL. Which means that they are essentially RAW images with no corrections applied. The images contain optical distortions, elevation distortion, terrain distortion, and they have not been corrected to Sea Level Datum. (The greater the elevation of your work area the greater the scale error) It's a great sales job they let you know how good the images are; they just won't fit till you buy the image. Read The EULA it is illegal to use those images without a commercial license in any commercial enterprise.
The images are first stereo rectified to remove distortions caused by altitude of the camera and difference in terrain elevation. They are then Ortho rectified to match a specific map projection usually UTM83 or (27) becauseTM is a simple transform. (In the Old Days we used equipment that used a lot of optical tricks to scale and re-project the image on to a production transparency) Now it is done digitally (Rubber Sheeting) typically with 20-128 match points per doqq.
Obtaining the images Global Mapper connects to several of the commercial vendors (Premium Content). The Hi-res Ortho-rectified images can be purchased at a cost of from $40 - $200 dollars per square mile. These will be in UTM83 extra charges for special projections. They will let you down load the images with watermarks before purchase to check coverage and resolution; but you can't save them.
Free Data: Global Mapper connects to the USGS national Map Server and the USDA Server these are 1 meter Ortho-photos. GM will re-project and write the files with the required geo ref in either tiff or ecw format. Or they can be down loaded as quads from the USGS map store. (Need to use GM14 to convert the GeoPDF to formats that C3D can use.)
Jim
Matrix3DSurveys
Thanks for the information and reminding me about Rubbersheeting the images. I forgot I had that capability with Raster 2014. Just Rubbersheeted a 0.3m JP2 and it looks pretty good.
