Civil 3D Forum
Best Error Message Ever...
17 REPLIES 17
Message 1 of 18
Sinc
2333 Views, 17 Replies
Still getting this in C3D 2012 SP1, for no apparent reason:
YEAH!
Sinc
17 REPLIES 17
Message 2 of 18
in reply to: Sinc
That's definitely packed full with helpful troubleshooting information.
Message 3 of 18
Sinc
Guess I'll just hit "OK"....  Smiley Happy
Sinc
Message 4 of 18
in reply to: Sinc
It means, "Warning... Exclamation Point Ahead".
Message 5 of 18
antoniovinci
in reply to: Sinc
Not only: you may even click onto white cross on red background...
Now seriously, try to restart Windows in "safe mode", then run Civil: does that funny alert show up..?
Message 6 of 18
neilyj666
in reply to: Sinc
I got this the other day too - seems a bit uncontentious though and not reproducible on demand - don't worry though they are bound to have sorted it out for C3D 2013.....Smiley Frustrated
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 7 of 18
AllenJessup
in reply to: Sinc
I get it too. Often when closing Civil.
Allen
Allen Jessup
CAD Manager - Designer
Message 8 of 18
in reply to: AllenJessup
Allen....I second that. I get that when closing, sometimes it's not even right away. 20-30 seconds go by then BAM!!! there it is.....
Message 9 of 18
MarySeufert
in reply to: Sinc
Gotta love the phantom error. I get it as well with C3D and less often with ACA. ~ Mary
EXPERT ELITE MEMBER
Message 10 of 18
rkmcswain
in reply to: Sinc
Glad I'm not the only one 🙂
Message 11 of 18
in reply to: Sinc
Yet another candidate for the Interface Hall of Shame.
I also nominate the interface for attaching and querying files within Map. Why is the dialogue box the sixe of a post-it note floating in middle of our nice, new jumbo monitors?
Just hit OK. OK?
Message 12 of 18
in reply to: Sinc
My new favorite error message......(see attached)
I didn't even get a chance to save a recover drawing (which is only useful half the time) and lost almost an hour of work. YEAH for autosave.....not really......
Message 13 of 18
I had this error message too.  Think I might have solved it though (in my case anyway).  I uninstalled all Google Earth for AutoCAD add-ons as well as Civil 3D object enablers.  The next time I opened and closed a drawing the exclamation point error message didn't appear.  Before it would appear every time I closed a session.
BTW, I'm running AutoCAD Map 3D 2012.
Message 14 of 18
andrewpuller3811
in reply to: Sinc
I was getting this error as well, on both my work pc and home pc with 2011, 2012 and 2013.
After seeing this post by David Lau at Up and Ready
http://upandready.typepad.com/up_and_ready/2012/08/revit-2013-the-yellow-triangle-in-an-exclamation-...
I tried the fix from the link (shown below) in the article regarding repairing .net 4 framework and it worked! Same procedure on windows vista 64bit and windows 7 64bit.
http://upandready.typepad.com/up_and_ready/2012/01/installation-net-repair-for-windows-7-the-easy-wa...
No more empty error box with a yellow triangle when I exit Civil 3d.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
Message 15 of 18
Just tried this, to no avail. Wish it worked. Because now I am getting this little bugger multiplied by 2 on all my versions of CAD, sometimes I'll have to get rid of three. Smiley Mad
~ Mary
EXPERT ELITE MEMBER
Message 16 of 18
c.suarez
in reply to: Sinc
This exclamation mark error is very annoying. I am using AutoCAD Structural Detailing 2012 and apparently this error is also present. I do not have a parallel installation, (version AutoCAD 2013), but Revit Structure 2013 is installed, side-by-side with Revit Structure 2012.
Message 17 of 18
Repairing the .NET installs did not fix the issue on any machines I've tried.  I am experiencing the error dialog on close of AutoCAD 2011 after having opened a file with vertical objects (Civil3D, etc).  The only fix that has worked is to repair AutoCAD 2011 after installing AutoCAD 2013.  I'm hoping Autodesk will release a fix for this issue soon.
Message 18 of 18
rkmcswain
I doubt we'll see a fix for this.
It's annoying at worst (at least here) so we just live with it.
Rail Community
