Civil 3D Forum
Berm/Ditch Design
2 REPLIES 2
scohen
485 Views, 2 Replies
Berm/Ditch Design
All,
What subassemblies should be used to design a simple berm/ditch? IOW, no
depth/shape is necessary, and the only design data I am concerned with is
fill/excavation and generating proposed contours. I have tried using
BasicLane w/DaylightGeneral and it works ok when I leave the depth, but when
I set the depth to 0, the subassembly disappears and becomes invalid until
I give it a depth again (I assume this works as designed). I tried using
just the LinkWidthAndSlope subassembly with DaylightGeneral on each side of
the assembly and the corridor width doesn't match the width I told it to be
for each side of the centerline (obviously half of the berm/ditch).
Any help is appreciated.
Thanks.
-Seth
2 REPLIES 2
in reply to: scohen
I have done extensive dyke and ditch work with Civil 3D. I have always used
the generic links with success. I'm not sure what your settings are, but
there would appear to be an error somewhere.
Matt Kolberg
wrote in message news:4985724@discussion.autodesk.com...
All,
Thanks.
-Seth
scohen
in reply to: scohen
Matt,
You are correct, I had it linked to a horizontal alignment (accidentally of
course :-).
Thanks for responding.
-Seth
Rail Community
