Civil 3D Forum
Benched wall quantities
36 REPLIES 36
Message 1 of 37
Neilw_05
1819 Views, 36 Replies
I have the task of determining the face area of a benched retaining wall from a corridor. I used a benched daylight subassembly to model the wall. Is there a subassembly I could use that will give me a benched wall with quantities?
C3D 2011
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
36 REPLIES 36
Message 21 of 37
fcernst
in reply to: SethHall
Did anyone hear back from Seth on this in 2010?
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
Message 22 of 37
Neilw_05
in reply to: fcernst
I never did.
Perhaps someone else will take up he challenge.
WIN 10 64 PRO
Message 23 of 37
fcernst
in reply to: Neilw_05
It's because it doesn't work Neil. I just found out the hard way.
Nice of him to get back with you and keep you and the Support forum in the loop, and well informed.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 24 of 37
SethHall
Wow... almost 3 years ago, good digging Fred Smiley Happy
The forums have changed quite a bit since then, but reading through this thread I can recall the issue... I apologize for not posting my results.
If I can recall completely I was never able to get this scenario to work, and it appears that Fred has verified it as well. I will be sure to pass this along, and feel free to leave feedback by following this link:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Seth Hall
Product Owner
Model Builder
Message 25 of 37
Neilw_05
For the meanwhile this similar thread suggests a technique that uses volume surfaces to determine the wall face areas:
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Looking-for-area-between-profiles/td-p/3841909
WIN 10 64 PRO
Message 26 of 37
SethHall
Great! Thanks Neil!
Seth Hall
Product Owner
Model Builder
Message 27 of 37
fcernst
Oh there's Seth.
... I will be sure to update with what I can find out."
Seth,
You suggested using QTO for this scenario to find the steep surface areas. This is what I did to try and solve the Wall Face surface area problem proposed in the Forum this week.
Looking for surface area on the steep surfaces is when it became readily apparent to me that QTO is using the 2D projected plan areas for Corridor quantities.
I'm sure you must have seen this behavior when testing QTO per your suggestion to be used for Neil's problem here back in 2010.
I further found out that through my testing that QTO formulas do not apply Subassembly depth parameters, multiplied by the Item Area, correctly for computing Material volume calculations. Research shows Autodesk was made aware of the QTO problems as far back as 2009.
What is the repair status for QTO from Autodesk development?
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 28 of 37
fcernst
Wow... almost 3 years ago, good digging Fred :smileyhappy:
I didn't have to dig. Neil supplied the thread this week.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 29 of 37
tcorey
Sorry to pipe in so late, but couln't you just extract feature lines from the benching areas, create surfaces from the feature lines and then go to the surface statistics and look at the 3D surface area?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 30 of 37
Neilw_05
in reply to: tcorey
That's a great suggestion Tim.
It would be nice to find a solution that works with QTO for easy reporting and estimating.
WIN 10 64 PRO
Message 31 of 37
fcernst
in reply to: tcorey
Tim,
Have you tested QTO?
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 32 of 37
tcorey
@fcernst wrote:
Tim,
Yes I have and QTO only reports 2D areas, hence the need for creating surfaces.
Tim Corey
Redding, CA
Message 33 of 37
fcernst
in reply to: tcorey
Have you put in a support request?
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 34 of 37
tcorey
No I haven't as I know it doesn't work so I suggest the workaround to my clients. I see in your other thread that you have done so and that the issue has been sent to development. Maybe we'll see a fix in a service pack or 2015, but for now I will continue to recommend the workaround.
Tim Corey
Redding, CA
Message 35 of 37
fcernst
in reply to: tcorey
Ok, but please if I can ask you send in a report request or product feedback since you know of the issue. It will be linked to the Case that has gone to development.
My research shows users have been confused about QTO for the past 4 years. This needs to get resolved.
The issue needs valuable input from resellers like you.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 36 of 37
tcorey
Fred, I have logged a case with Autodesk.
I am going to look at a possible way to use QTO formulas and will follow up if I can come up with a solution that works.
I am also going to look at using Corridor Solids. That might be a simple way to calculate an answer as well.
Tim
Tim Corey
Redding, CA
Message 37 of 37
fcernst
in reply to: tcorey
Thanks. I'm really hoping we can get a Hot Fix for this within a couple weeks.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Rail Community
