Hello, everyone.
I'm having some problems about the bench feature lines when using Civil 2012. I don't know why, but some of the features just try to connect to other miles away from the correct place.
It looks like the lines 'explode' when the bench extension is shorter than the frequency of the corridor. If I reduce the frequency from 50 to 20 meters, some of them disappear, but not all. And also, when I create the corridor surface, it seems correct, and the bench is not 'exploded'.
I've also tried changing the features to inward, outward, connect extra points or not, but couldn't solve the problem.
In 2013 version there is no problem, as you can see.
2013:
2012:
The corridor surface is correct, but the feature...
