I am using Batch files created under the Survey Command. I want to list the coordinate value of points created, What setting do I set to show this.
Batch files allows you to use the Survey Command language to create points at intersections of lines or from the centerline of a survey. In using Batch Files the output goes into an Output file. When we were using LDD this Output file (attached OP401.pdf) would list the coordinate of the point being created. In Civil 3D this appears not to be an option (attached Output.pdf) and it does not list them unless you ask for it to List a series of points. I have attached two examples one from LDD and one from Civil 3D.
