AutoCAD Civil 3D General
Valued Contributor
pserpas
Message 1 of 5 (1,510 Views)
Batch Convert v.2012 .dwg Files to 2009 .dwg?
1510 Views, 4 Replies
05-21-2012 05:53 AM
I've got a client who requested a project be re-submitted in Autocad 2009, and there are a bunch of files.  First off, when I go to do a saveas, I don't even get an option to convert to 2009, just 2007 and earlier.
Will I have to open each and every file to do the saveas?
Windows 7 x 64
Nvidia GeForce GTS 450
8 GB Ram
Intel Core i5-2310 @ 2.90 GHz
v. F.107.0.0 AutoCAD Civil 3D 2012 SP1
Valued Contributor
pserpas
Message 2 of 5 (1,509 Views)
Re: Batch Convert v.2012 .dwg Files to 2009 .dwg?
05-21-2012 06:17 AM in reply to: pserpas
After some searching, I found an Autodesk program called DWG TrueConvert, however, it seems that the only legitimate download of this is for Autocad 2007.  Can anyone confirm that?
Windows 7 x 64
8 GB Ram
TRogers
Message 3 of 5 (1,503 Views)
05-21-2012 06:31 AM in reply to: pserpas
DWG TrueView will do it.  It's a free download.
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
AllenJessup
Message 4 of 5 (1,495 Views)
05-21-2012 07:12 AM in reply to: pserpas
Does the client want AutoCAD 2009 files or Civil 3D 2009 files. In AutoCAD the r2007 files are the same format as the r2009 format. That's why you don't see an option to saveas 2009. Realize that if you use Saveas or DwgTrueConvert all of the Civil 3D objects will be unusable. Some will be proxy objects and some may not make it at all.
To get back to r2007(2009) you would need to use the ExportToAutoCAD2007 command. This will explode all the Civil 3D objects before exporting the file. But you can't do it as a batch process unless you create the process yourself.
If you need to go back to Civil 3D 2009, let us know. It's a different process.
Allen
Valued Contributor
pserpas
Message 5 of 5 (1,489 Views)
05-21-2012 07:41 AM in reply to: AllenJessup
Thanks for the info.
Windows 7 x 64
8 GB Ram
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
