I am not sure that my answers are correct or not , so i need your help to check them
Q\Which of the following is NOT a Surface Label that is available in the default install of ACAD Civil 3D?
Solved by ToddRogers-WPM. Go to Solution.
A)Spot Elevation Labels.B)Cut/Fill LabelsC)Contour LabelsD)Slope LabelsI believe that B is a correct answer .Q\How is the next Point Number to be used in a drawing controlled?A)Using Label Styles in Toolspace/SettingsB)Right Click on Survey Points in the Survey TabC)With Points Identify in the expanded area of Create Points toolbarD)Right Clicking on Survey Points in the Prospector tabI believe that B is a correct answer .Q\An Easement isA)a transfer of ownership of propertyB)the right to use specified property for a particular purposeC)granted to your neighbor because they decide they want itD)required whenever a new driveway is builtI believe that B is a correct answer .Q\A Quick Profile is kept and available later when you save or exit a drawingA) TrueB) FalseI believe that B"False" is a correct answer .Thank you
