Civil 3D Forum
Basic questions
2 REPLIES 2
250 Views, 2 Replies
Basic questions
I am not sure that my answers are correct or not , so i need your help to check them
Q\Which of the following is NOT a Surface Label that is available in the default install of ACAD Civil 3D?
A)Spot Elevation Labels.
B)Cut/Fill Labels
C)Contour Labels
D)Slope Labels
I believe that B is a correct answer .
Q\How is the next Point Number to be used in a drawing controlled?
A)Using Label Styles in Toolspace/Settings
B)Right Click on Survey Points in the Survey Tab
C)With Points Identify in the expanded area of Create Points toolbar
D)Right Clicking on Survey Points in the Prospector tab
Q\An Easement is
A)a transfer of ownership of property
B)the right to use specified property for a particular purpose
C)granted to your neighbor because they decide they want it
D)required whenever a new driveway is built
Q\A Quick Profile is kept and available later when you save or exit a drawing
A) True
B) False
I believe that B"False" is a correct answer .
Thank you
2 REPLIES 2
ToddRogers-WPM
in reply to: 985858485
B)Cut/Fill Labels
C)Contour Labels
D)Slope Labels
Q\An Easement is
A) True
B) False
Thank you
Todd Rogers
BIM Manager
Blog | Twitter | LinkedIn
in reply to: ToddRogers-WPM
Thanks TRogers ,
Rail Community
