The catch point is in the shape. Take a look at the attached PDF. Without running cross-sections and running average end that way, is this possible to run in a volume surface?
Edit: Shape is aqua that needs quantified. This is just a cross-section of the plan view.
Try merging together your pad surface and your existing ground surface to create a composite. Then run your volume surface between your aqua surface and the composite surface.
Thank you for replying back. I never updated that I found my quantity. I basically cut the hatched shape in two parts and ran quantities from them.
