Civil 3D Forum
Basic area label
46 REPLIES 46
Message 1 of 47
sjg
16093 Views, 46 Replies
Basic area label
Asked this about a year and a half ago when we converted from Survcadd and still haven't found any solution and now that I've read 2013 is going to include line labeling capabilities by selecting 2 points rather than selecting linework. Is there going to be a way to label an area without creating a closed polyline or parcel, where it works the way a hatch works. So if I selecting in the middle of multiple individual intersecting lines, it labels the area.
Steve Goessling
Land Consultants
Civil3D 2015
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
46 REPLIES 46
Message 21 of 47
sjg
in reply to: dana.probert
Found this lisp from a previous discussion group seems to work pretty good and exactly what I was looking for, Was wondering if someone could look to see where I could eliminate the number and just display the area. Would like the area to read on the top line 43,560 SF and on the next line 1.00 AC.
Steve Goessling
Land Consultants
Civil3D 2015
Windows 7, 64 bit
16 GB RAM
Nvidia Quadro 600
Message 22 of 47
antoniovinci
in reply to: sjg
I've just tuned the brilliant lisp by Tcorey, in order to match the Neilyj request - run the attached file issueing SQM
Message 23 of 47
neilyj666
in reply to: antoniovinci
Thanks for the update - but it doens't seem to work correctly. It displays odd results on the command line and doesn't add the text to the drawing
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 24 of 47
antoniovinci
in reply to: neilyj666
I'm sorry, Neil, but in my Map2006 it works perfectly, as you can see in the attached file.
If i find a free hour today, I'll try to download a C3D trial to test it: stay tuned.
Message 25 of 47
neilyj666
No problem
Message 26 of 47
antoniovinci
Basing myself on your screenshot, I corrected the routine: please run it with SQM4NEIL
It doesn't work for me under Map2006, and what about you?
P.S.
To see the "2" superscript, you must use a font supporting Unicode, e.g. simplex.shx or Truetype.
Message 27 of 47
neilyj666
in reply to: sjg
Getting there - but the text height as input (5 in this case) is also passed to the rotation parameterSmiley Sad
Message 28 of 47
antoniovinci
As stated by Timmy "The current text style must have a 0 height", but actually yours appears as follows:
so try to set 0 in your ANN2MM style, then run the attached file with AREALABEL
Message 29 of 47
neilyj666
Many thanks - that works fine nowSmiley Happy
Message 30 of 47
antoniovinci
You are welcome, and pay attention to this point: in the last AREALABEL.LSP I've added a command to erase the temporary boundary at each loop, so the drawing stays light.
Message 31 of 47
antoniovinci
in reply to: sjg
Corrected, now it shows a continuous result on two lines (run with SJG):
http://novara.orangespace.pl/civil3d/area_sf-ac.zip
Message 32 of 47
rkmcswain
in reply to: sjg
@sjg wrote:
Asked this about a year and a half ago when we converted from Survcadd and still haven't found any solution.....
Carlson (SurvCADD) is very rough around the edges, but I'll give them credit for having a plethora of simple tools like you mention - things that require 8 steps, lisp, etc. to do in Civil 3D (and LDT). Autodesk could learn a lot by taking at look...
Message 33 of 47
jmayo-EE
in reply to: rkmcswain
That is definitely an area that could use some work. For new users there is a lot to digest when you need to get the work done. The user has to know the command and where it is executed from (toolspace, ribbon commandline). As for the seasoned vet this is just traffic in your workflow.
John Mayo
Message 34 of 47
rkmcswain
in reply to: jmayo-EE
@Anonymous wrote:
That is definitely an area that could use some work..
Another is a simple point to point inverse.
In Carlson:
  1. Type in "i"
  2. <enter the first pt #>
  3. <enter the second pt #>
  4. voila, the result.
  5. repeat steps 2 and 3 to repeat
In Civil 3D:
  1. Click Analyze tab
  2. Click on Inquiry Tool
  3. Click on the drop down
  4. Expand the point section
  5. Click on 'point inverse'
  6. Click in the field for point 1 number
  7. Move hand to keyboard and enter the first point number
  8. Move hand back to mouse and click in the field for point 2 number
  9. Move hand back to keyboard and press enter.
  10. Result
  11. Repeat steps 6,7,8,9 to repeat, until you close the palette, then repeat 1-10
Message 35 of 47
troma
Sounds like another area that could benefit from allowing the use of TAB and ENTER like a spreadsheet.
Mark Green
Working on Civil 3D in Canada
Message 36 of 47
jmayo-EE
Yep we need to do a lot of navigating in this app. I just changed my default staoff lbl style for sections on a flood study. 9 clicks since toolspace was off.Now if only the Addlabels dialog could actually do that I could get back to the study.
John Mayo
Message 37 of 47
antoniovinci
Oops, the attachment of post #31 died in the meanwhile, here's it again...
Message 38 of 47
AllenJessup
Yes. OOTB it's very kludgy. That's why I simplify things with toolpallets and aliases. I type IV which starts the CgList command then either pick the point nodes or use the 'PN or 'PO transparent commands. I also have "Line and Arc Information" (CgList) in a toolpallet and a 3rd party app [SmartDraft] that sets D to give the bearing and distance between two points.
Allen Jessup
Allen Jessup
Engineering Specialist / CAD Manager
Message 39 of 47
TerryDotson
The process can be simplified in Civil3D by grabbing AECCINV in the Free Stuff section of the site below.
  1. Type INUM or INAM (depending on whether numbers or names are used).
  2. Enter the First Point ID.
  3. Enter the Second Point ID.
  4. The results are displayed.
  5. Press Up+Arrow and Enter to repeat.
Message 40 of 47
rkmcswain
in reply to: TerryDotson
I'll forward this to the person who needs it. Thanks.
Rail Community
