AutoCAD Civil 3D General
Joe-Bouza
Message 11 of 16 (176 Views)
Re: Basic Lane Sub-Assembly and Targets........
01-18-2013 05:01 AM in reply to: BrianHailey
Dats da one. :smileywink:
Maybe I'm reading too much between the lines but I steer clear.
In my earlier experience I used a BasiCurb and because it has no offset on the face I believe it caused corruption in my TIN, at the time.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
BrianHailey
Message 12 of 16 (172 Views)
01-18-2013 05:50 AM in reply to: Joe-Bouza
I too stear clear of the basic subassemblies. Why? Well, I remember them causing issues several releases ago. What where those issues? I honestly don't remember.
If the only reason you are doing something is because that's the way you've always done it, you're doing it wrong.
Perhaps I should go revisit the basic subs and see if they still cause issues or not.
Distinguished Contributor
taneum
Message 13 of 16 (159 Views)
01-18-2013 10:04 AM in reply to: Jeff_M
Jeff_M wrote:
Instead of a Basic Lane, use a UrbanSidewalk with a 0' inside width, 2' walk, 0' outside width. Attach the ret.wall to this, the sidewalk width can be set to a target.
Yep that worked Jeff.  The only thing I ran into was, I put the "shape trapezoidal" sub-assembly under the sidewalk and in my section where the urban sidewalk was gone because the wall took its place, the shape trapezoidal sub-assembly moved up in the place of the sidewalk.  I didn't get this at first but when I targeted that sub-assembly to the same target lines as my sidewalk was targeted to, the shape trapeaoidal sub-assmbly went away also.  Make sense?  Kinda wordy but I think it doing what I need it to.
Jeff_M
Message 14 of 16 (154 Views)
01-18-2013 10:24 AM in reply to: taneum
Yes, that makes sense. Glad it worked for you!
Joe-Bouza
Message 15 of 16 (140 Views)
01-19-2013 07:09 PM in reply to: fcernst
Your absolutley right Fred; they would never put anything in the program that would screw things up :smileywink:
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
Joe-Bouza
Message 16 of 16 (139 Views)
01-19-2013 07:10 PM in reply to: BrianHailey
good point
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
