After bringing in a Bing map I zoom into the area I want and then save it to a new AutoCAD drawing (using the option under maps on the task pane). When I open the new drawing the map is now a raster image as expected, but instead of cropping it to the area I zoomed in to (which I saw demonstrated on a youtube video) it is the entire map. Is there a setting I am missing?
Thanks in advance for any help..
Solved by ToddRogers-WPM. Go to Solution.
Before saving it to an AutoCAD drawing, you must right click on the connection and select Resample. This will crop it.
All,
I have a connection to Bing Maps
Can I get step by step directions on cropping and saving.
I can't find the command to resample or save as.
Thanks.
Todd - Thanks for the reply and the solution. I am surprised at the image quality after resampling...
