Civil 3D Forum
Band Style alignment end station (Civil 3D 2009)
9 REPLIES 9
Message 1 of 10
wsargent
2068 Views, 9 Replies
Is there a way to have bands not station the end of an alignment?
For example my alignment is 2+09.85 long. I have the profile set to extend to the next station so it displays from -0+50 to 2+50 with the extra unwanted station at 2+09.85 using the stock 'Elevations and Stations' style.
__________
AutoCAD Civil 3D 2016 SP3.0, built on: AutoCAD 2016 SP1, Map 3D 2016 SP2
Dell Percision T5810: MS Windows 10 Pro; Intel Xeon CPU E5-1620 v3 @ 3.50 GHz, 16.00 GB RAM, NVIDIA K2200 4.00 GB Memory
9 REPLIES 9
Message 2 of 10
atwitsend74
in reply to: wsargent
Honestly, I'm interested in the official answer to this as well.
The only work-around we've been able to figure out (provided you can't falsely extend the alignment) is to limit the profile view stationing to (in your example) 2+09.84.  The difference in length is negledgable, but your grid will end right at the end of the profile (I sometimes make a false grid to extend for asthetic reasons)
My preferred solution (used with pipes, not with streets) is to extend the alignment past the last structure for 20-30 feet (our alignments are non-plotting anyway), and then limit the length on the profile view to say 2+25 (per your example).  It keeps the structures visible, but avoids the annoying end station and looks much nicer.
Jason B
Office CAD Guy
Oh... and Civil Engineer
Civil 3D 2009 and 2013
(wow that was a jump)
64-bit XP
i7 w/ 8GB Ram
ATI Radeon HD 2600 PRO
Message 3 of 10
wsargent
in reply to: atwitsend74
Since I have not received nay replies...
What if I upgrade the project from the Civil 3D 2009 platform to the Civil 3D 2011 platform? Does that give me access to do what I am looking for?
__________
Tags (1)
Message 4 of 10
Joe-Bouza
on the bands tab of the profile view properties scroll to the right:
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
Message 5 of 10
wsargent
in reply to: Joe-Bouza
I double checked all of my profiles and both the label start station and label end station are unchecked by default.
__________
Message 6 of 10
Joe-Bouza
And they are getting labels?
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
Message 7 of 10
wsargent
Yes
__________
Message 8 of 10
andrewpuller3811
In the Bands Tab of the profile properties, Click the button under Geometry Points, as shown in the image Joe attached above.
This will bring up a form called "Geometry Points to Label in Band".
On the Alignment Points Tab, Untick the check boxes next to  "Alignment Beginning" and "Alignment End", then click the "OK" Button.
Now you just have to do that for each band.
You may still get labels, which will probably be down to the profile start and end also in the "Geometry Points to Label in Band" form on the "Profile Points" tab.
There could also be a start label from the major station labels in the band style. You can stop this one by setting the profile start to be 0.001, which will stop the first major station label, but make the rest of the profile view look as expected.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
Message 9 of 10
manually enter the ending station to something before the true profile end. for example is the profile ends with station 3+52.36 uncheck the ending station as Joe posted. now enter an ending station of 3+51 thay should keep it from placing a double label in the band.
-Sean
Just a CAD Manager for a Civil Engineering firm...
Message 10 of 10
Thanks a lot
u solved my problem too.
Rail Community
