I am trying to get Slide Line Creation tools to set my back lot line at a set lot depth I changed all the setting in the dialog box and it still will not set my back of lot line. if I do not have a predefined back of lot line before hand it will extend the lot line all the way a cross the parcel. Anyone know how to have the slide line creation tool work and create the back lot line?.
JBR,
First order of business is to make your Big Kahuna, Main Parcel. Then you can use the Slide Line Tool. Here's an excellent short video on the Parcel Tools:
https://www.youtube.com/watch?v=iGFMoAk8988
Dave
Dave Stoll
Las Vegas, Nevada
PointDump
Thank you for your Reply
I understand the lot creation method, the process that I want to accomplish is can the creation tool set you back line to your lots in an open parcel and create lot inside the bigger parcel lets say for example lot's 80' wide x 122' deep and the parcel is 1000' wide x 500' deep I pick the frontage and start my lots it will not set my back lot line at 122' it highlight the whole 500' deep instead of 122' deep. The only way I can make it work is if I add the back of the lots line as objects before hand.
Thank You
JBR,
Apologies. I don't think I'm understanding the problem. Can you post a Screen Grab to clarify?
Dave
Dave Stoll
Las Vegas, Nevada
JBR,
You'll need to close that Leaky Bucket to make a Parcel. You won't be able to use the Slide Line Tool for that.
Dave
Dave Stoll
Las Vegas, Nevada
