I am just now switching to Civil 3D from a longtime use of LDD. I really, really love the build selection set command. I think someone else commented on the absence of it in an earlier blog. Is it still not in Civil 3D 2011? Any suggs?
I missed it for a while (used LDD and it's predecessors for a long time).Now I don't even think about it. Things I now use:
SelectSimilar (right-click menu when you've selected something)
QuickSelect (on the Properties Palette)
FILTER - Command
Feel free to add your name and comments to the wishlist item:
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-Wishes/Selection-set-utility/td-p/2563826
There more people who ask for things, the more likely they are to be at least looked at.
i used to be a big fan of selection set (SS command) in Land Desktop, and i have always wanted to know how i can do a selection like this without it:
select all text in layer XX, which have a ROMANS text style, a text height of 12 units, and is set to color 1.
i guess you can probably do this by one of the techniques (or combination thereof) that you mentioned before; if you can share the trick, it would be a big help.
And this very soon:
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-Wishes/Selection-set-utility/m-p/2755066#M6291
@Jeff_M wrote:I missed it for a while (used LDD and it's predecessors for a long time).Now I don't even think about it. Things I now use:
FILTER - Command
This thread prompted Jeff to add the BuildSelectionSet command to the Sincpac-C3D.
At first, I was thinking like him, that with SelectSimilar and other options, there wasn't much need for BuildSelectionSet. But now that I've had this command for a couple of weeks, I can't believe how often I've used it. It's amazing how useful it is, even in Civil 3D.
Thanks Jeff!
