If you are using 2013 (not sure when it changed..?), you can't simply type in BLIPMODE any more
Command: blipmode Unknown command "BLIPMODE". Press F1 for help.
But you can use lisp to do the trick
Command: (setvar "blipmode" 1) 1
Holy Cr__, they actually got rid of one of those commands that nobody uses any more!!
Now I'm getting all nostalgic...
Sometime in the next few years a new user will put up a wishlist item asking for a way to display recent pick locations, and then this will be re-introduced as a new feature.
Darren, I had honestly never heard of BLIPMODE until I read your question. Then I typed it in my machine, and found out what it was. It turned it on, no problem. I am working in 2011, and as someone pointed out they removed the command from 2013.
Please, let us know what you want this on for. I find it interesting, I would really like to know.
Mark Green
Working on Civil 3D in Canada
At the command line type REDIFINE and then BLIPMODE. This will ebale the blipmode command again. It wasn't removed, just undefined.
