Civil 3D Forum
Autosave
4 REPLIES 4
ronpemberton7479
295 Views, 4 Replies
Autosave
Why does AutoCAD turn off the autosave randomly? I always have my autosave turned but on two occasions in the last two days I have went to recover a drawing after a crash and the autosave is turned off with no autosave drawings available. This has also happened a number of times in the past in different versions. I am running civil 3D 2012 currently.
4 REPLIES 4
sboon
in reply to: ronpemberton7479
Autosave is turned off during the publish process.  If you crash during that step then it's still turned off when you restart.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
Kind of like the filedia setting, It often gets turned off after a crash. A lot of folks use a startup script that turns it on. If you haven't yet, you should get in the habit of checking after ACAD crashes.
neilyj666
in reply to: KirkNoonan
Yes, this is my preference; add the following to acaddoc.lsp
(setvar "SAVETIME" 10)
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
rkmcswain
in reply to: neilyj666
Of if you really want to be on top of it... piggyback it on a command you use often..... for example:
(defun c:E ()
 (setvar "savetime" 10)
 (command "._erase")
R.K. McSwain     | CADpanacea | on twitter
Rail Community
