We have a raster drawing that we're trying to vectorize using Raster Tools within Autodesk Infrastructure Design Suite (Civil 3d) 2014. However the process is slow going having to convert each line within the raster drawing manually. Is there a way that Raster Tools can automatically vectorize all lines within the drawing instead of picking each and every line?
This should be posted in the Raster forum...
http://forums.autodesk.com/t5/AutoCAD-Raster-Design/bd-p/134
neilyj (No connection with Autodesk other than using the products in the real world)
@ShawnMcCorkle1211 wrote:We have a raster drawing that we're trying to vectorize using Raster Tools within Autodesk Infrastructure Design Suite (Civil 3d) 2014. However the process is slow going having to convert each line within the raster drawing manually. Is there a way that Raster Tools can automatically vectorize all lines within the drawing instead of picking each and every line?
No easy button if that's what you want. The reason Raster Design works the way it does is to give "you" control over the creating of the lines/plines, and to use only the lines you need.
