Civil 3D Forum
Automatic Save is not creating Temp files
13 REPLIES 13
Message 1 of 14
Nikki101
2163 Views, 13 Replies
I have my automatic save turned on and set to 10 mins.  I can visual see Civil automatically saving (as I have to wait a few seconds for the process) but it is not creating the temporary files.
I used to work fine, and I can see the last file that was created - a couple of weeks ago, but now it has just decided to stop creating these temporary files.
Does anyone know why this would happen?
It really makes this option useless if there is no temp file to get my lost information from when I crash.
Any help would be appreciated.
Thanks.
Rob
13 REPLIES 13
Message 2 of 14
Jeff_M
in reply to: Nikki101
Try changing the location from the default of "C:\Users\USERNAME\appdata\local\temp\" to "C:\Users\USERNAME\appdata\local\temp\Civil3D". If this then works, I suggest emptying your TEMP folder as it is likely too full of junk which can lead to other, more serious, issues.
Jeff_M, also a frequent Swamper
Message 3 of 14
Nikki101
in reply to: Jeff_M
This seemed to work!  Thanks.
Message 4 of 14
Nikki101
Although, I didn't bother to try changing the location from the default of "C:\Users\USERNAME\appdata\local\temp\" to "C:\Users\USERNAME\appdata\local\temp\Civil3D".  I simply deleted a bunch of unwanted files from my standard temp file folder (primarily targeting the ones related to the file I which was working on that didn't seem to be auto saving, and everything seemed to be back to normal after that.
Thanks again.
Rob
Message 5 of 14
rkmcswain
in reply to: Jeff_M
I second that. I've seen the %temp% directory grow to a point where AutoCAD starts doing strange stuff, namely crashing often. Keep it clean 😉
R.K. McSwain     | CADpanacea | on twitter
Message 6 of 14
Nikki101
in reply to: rkmcswain
Do you know of any file types that I should not be deleting out of the temp folder?
Thanks.
Message 7 of 14
AllenJessup
I don't see that happening on my computer and I specifically stop AutoCAD from deleting any of those files.
Allen
Allen Jessup
CAD Manager - Designer
Message 8 of 14
rkmcswain
Thanks.
There shouldn't be anything there that can't be deleted. But for example, just as you might want to keep the .sv$ files for AutoCAD, there could be files related to other applications that you might want to keep.
Having said that, I wipe it all out. Actually, I have a script on the server that does this for everyone, retaining files from the last X number of days
Message 9 of 14
rkmcswain
in reply to: AllenJessup
Allen
I've seen %temp% directories with tens of thousands of files/subdirectories and it does affect AutoCAD, or at least the perception of if affecting AutoCAD is there, because cleaning that out fixes the crashing.
I wasn't talking about just .ac$ and .sv$ files, but all of the other files windows and other apps place there too.
I guess if you have a dedicated directory for AutoCAD temp files, it wouldn't get filled up as often and/or soon.
Message 10 of 14
AllenJessup
Yes. I do have a dedicated directory. About once a month I go in and delete all but the .SV$ and the .BAK files. Every six months or so I write them on to a DVD and erase all but about a weeks worth. I only do this for myself. I tell everyone else to just delete all but the recent ones. I pretty paranoid about having backups.
Allen
Allen Jessup
Message 11 of 14
troma
In my expirience the .bak files get saved to the same place as the .dwg
Is there a setting to change this?
Mark Green
Working on Civil 3D in Canada
Message 12 of 14
AllenJessup
in reply to: troma
I still get .BAK files with the drawing files. The .BAK of the .SV$ files seems to be an artifact of my denying the System the right to delete files in my
Allen Jessup
Message 13 of 14
MikeEvansUK
In options "Save backup copy with save" will save bak file to same directory as the originating file.
The autosave and Incremental save will save sv$ and bak files. Set incremental save as 90. This will in effect perform a full save every x minutes otherwise it will be a partial save.
The above will create and use a lot of space in the temp directory so will need deleting periodically.
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Message 14 of 14
AllenJessup
Something going wrong with my posts.
I still get .BAK files with the drawing files. The .BAK of the .SV$ files seems to be an artifact of my denying the System the right to delete files in my dedicated folder. The MoveBak command will change the folder for the regular .BAK files.
Allen
Allen Jessup
Rail Community
