I have grading criteria sets that are automatically being created, and I'm just wondering why? Even better, how do I prevent it?
They look like the following.
[Criteria Set Name]
[Criteria Set Name].1
[Criteria Set Name].2
[Criteria Set Name].1.1
[Criteria Set Name].2.1
[Criteria Set Name].2.2
Ad infinitum
It's a little obnoxious to clean them out so any help would be appreciated.
I know this was posted over 2 years ago, but I've been having the same problem in 2014. I think I've found a way to get rid of them, so here goes...
NOTE: _PURESTYLES WILL DELETE ALL STYLES THAT ARE NOT SPECIFIED AS A DEFAULT OR IN A COMMAND, SO BE SELECTIVE IF YOU NEED TO. If you run it multiple times, you may be able to select the specific styles you want to delete.
Hope this helps...
I believe these are created in your file when you copy/paste grading/fline data to and from the clipboard.
John Mayo
