Civil 3D Forum
Automated linework
19 REPLIES 19
Message 1 of 20
914 Views, 19 Replies
Automated linework
We are now working in civil 3D 2011, and have started using the .txt files now instead of the fieldbooks of the past. I have created a Description key set, along with a figure prefix database and a linework code set. everything works fine as long as the field crews use EP1, EP,2 EP3, ETC.. But we would really like to utilize the Begin and End function of this. I have unchecked the box that says Automatic begin on figure prefix match, but still no luck. I have also checked the linework code set and it all looks good <Space> delimiter etc.., any help would be greatly appreciated thanks.
19 REPLIES 19
Message 2 of 20
mathewkol
EP1 B will work nicely to start a new figure unless you've edited the linework code set.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 3 of 20
in reply to: mathewkol
yeah, i have tried using the B EP or E EP, but When i import the .txt file in it does not draw the linework. like i said if i have the box checked automatic begin on figure prefix match and use EP1, EP2 ETC.. it works fine. but we do not want to change the description everytime we need to break a line.
Message 4 of 20
mathewkol
If you have that toggle unchecked you MUST use the begin and end codes. If it's checked then you don't. That's just the way it works. You don't need to use a different description to break a line just the E and B codes.
Matt Kolberg
Message 5 of 20
david.zavislan
Not sure if it is just a typo in your post, but the linework codes need to be entered after the point codes:  EP B and EP E.
David Zavislan, P.E. | Wood Rodgers, Inc.
Message 6 of 20
mathewkol
in reply to: david.zavislan
I believe this can actually work both ways.
Matt Kolberg
Message 7 of 20
I have edited the .txt files to try both ways, still no luck.
Message 8 of 20
Yup, tried both ways editing the .txt file to reflect the EP B or B EP, no luck
Message 9 of 20
Could it be a problem in My Description keys Format, i have all format set to $*. and most of my codes are EP*, FNC* etc..
Message 10 of 20
mathewkol
Desc keys have no bearing on what happens with survey figures.
Matt Kolberg
Message 11 of 20
mathewkol
I assume you have the button "process linework..." set to on when you import the txt file?
Matt Kolberg
Message 12 of 20
yes i do.
Message 13 of 20
JessicaPalmer
I am not sure if this has already been addressed but I want to make sure.  You should be brining in your .txt file using the "Import Survey Data" function, and not "Points from file". Points from file will not use your description keys and line code sets on import. Make sure that the appropriate Figure prefix database is current.
Good Luck,
Jessica Palmer
Message 14 of 20
...and they are case sensitive.
Jessica Palmer
Message 15 of 20
mathewkol
in reply to: JessicaPalmer
Actually Jessica, importing points from a file wlil assign description keys.  You're correct in that no figures will be drawn, however.
Matt Kolberg
Message 16 of 20
got it! my .txt files were space delimeted, needed to be comma. works great!!
Message 17 of 20
dgordon
what's the command for editing the linework code set?
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
Message 18 of 20
tcorey
in reply to: dgordon
On the Survey tab, expand Linework Code Sets, right click the set you want to edit and pick Edit....
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 19 of 20
As others have said, the codes work fine either before or after the description but I always recommend that they go after the description. If you put the code before the description, then your Description Key Set will see the linework code as the description of the point and that totally messes things up.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 20 of 20
Thanks for clarifying that Brian.  We have always put them after the point code so that description keys would function properly.  Just assumed that was the only option.
Rail Community
