AutoCAD Civil 3D General
Message 1 of 3 (495 Views)
Accepted Solution
Autocad Map Message - Incorrect cache file directory in the acadmap.ini file
495 Views, 2 Replies
05-18-2012 07:38 AM
can someone tell me why i keep getting this message Autocad Map Message - Incorrect cache file directory in the acadmap.ini file when i first start Civil 3d 2012 and open a drawing.
thanks,
Gerry
*Expert Elite*
Alfred.NESWADBA
Message 2 of 3 (491 Views)
Re: Autocad Map Message - Incorrect cache file directory in the acadmap.ini file
05-18-2012 08:09 AM in reply to: glacoste
I haven't seen this message at my start of Civil3D, but look to command _MAPOPTIONS (I think also MAPIOPTIONS has a directory to be defined), there you'll find settings for temp-folder. Try to change/to correct them.
HTH, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Message 3 of 3 (488 Views)
05-18-2012 08:40 AM in reply to: Alfred.NESWADBA
thanks Alfred,
I found out what it is. short story, after our company layed of a bunch of I.T. employees they put us on lock down for certain directories "C:\ProgramData\Autodesk\C3D 2012\MapCache\" being one of them. once i get that opened it should be good.
thanks again,
Gerry
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
