I have installed Civil 3D on a new laptop and after about 1-2 minutes autocad crashes. I have windows 8. The computer has an AMD processor with6 Gigs of ram.
Solved by AllenJessup. Go to Solution.
windows 8 is not supported
do a search on these forums
this has been disscussed already
DarrenP
Allen Jessup
CAD Manager - Designer
I recently purchased a new lap top as well (intel I-7) with 16 ram and 2 video. I had no problems untill my file sizes increased. My current working file is now 50m with 4 x-refed files adding another 550m.
My initial problem was Japanese error messages (a sign of installation problems?) and later fatal error messages resulting in failed recoveries. My current work-around is to save constantly and manually copying the working file often. Depending on workload it may be as often as ten minutes. I keep several x-refed layers frozen as well and plot or export via truview. Autodesk products have always had a problem freeing up memory. Frequent "total" re-boots always helped with this and still do.
I have my fingers crossed that soon we will have hot-fixes or service packs to fix this as I have to update this project in 2-4 weeks.
