Civil 3D Forum
Autocad Civil 3D Slope Analysis
10 REPLIES 10
Message 1 of 11
10050744
6883 Views, 10 Replies
Hi Guys,
I know some people may have already posted some stuff already about slope analysis but I could do with a direct answer to my question.
I am new to Civil 3d and have been learning it over the past month by myself, I have a reasonable good handle of the software as I have been using regular cad for the past couple of years.
I have been given a project for college and part of the project is as follows:
 Provide a Slope Analysis Plan which indicates the main surface water flows within the site and identifies slope gradients in coloured bands of:
>1 in 3
1 in 3 – 1 in 5
1 in 5 – 1 in 10
< 1 in 10
I understand the slopes, ranges and percentages, do I need to change the style of the slope analysis to achieve the above process???
Any help would be greatly appreciated.
Best Regards,
David.
10 REPLIES 10
Message 2 of 11
BrianHailey
in reply to: 10050744
You need to change the style of the surface to a style that will display the results of the slope analysis.
You also need to run the analysis. Choose the number of ranges you want (in this example 4) and then, after running the analysis, change the properties of each range.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 3 of 11
jmayo-EE
You need to perform a Elevation Surface Analysis from the Surface's Properties dialog and make sure the surface style used displays the elevations.
John Mayo
Message 4 of 11
jmayo-EE
in reply to: BrianHailey
Sorry Brian I didn't mean to repeat this but I did catch my mistake. Elevation analysis should be slope and the style should display slopes. Same stuff different calc. 😉
John Mayo
Message 5 of 11
10050744
Brian,
I have run the analysis, I understand the ranges etc. How do I go about converting the ranges above into percentages.
From the example above a 1: 3 is 33.33% but then they want 1:3 to 1:5 which is 33.33% to 20%??
Do you understand where I am coming from or do I just add the 20% to the 33% to give me a 1:5 slopes??
Am I just over complicating it or would I be better to just run seperate analysis of the surface for each???
Thanks for your assistance, much appreciated.
David.
Message 6 of 11
BrianHailey
Just type in 1:3 or 1:5 for the slope.
GEI Consultants
My Civil 3D Blog
Message 7 of 11
10050744
Brian,
Thanks very much for your assistance, especially the video which helped immensly.
I have one other question Brian.... Can you overlay/ underlay your original contours ontop/beneath the slope analaysis??
Thanks again.
Best,
David.
Message 8 of 11
neilyj666
Think you'd need to create a new surface, paste the original one in and style as required
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 9 of 11
BrianHailey
Just turn on the display of the contours as well as the slopes in the style.
GEI Consultants
My Civil 3D Blog
Message 10 of 11
twtaylor51
Is it possible to save the settings for the Range Details once they have been customized? I need to run an analysis on many different surfaces that will always have the same paramter settings.
Message 11 of 11
neilyj666
in reply to: twtaylor51
I think there is a tool in the UKIE country Kit that may be able to do this....
Rail Community
