Civil 3D Forum
Autocad Block symbols
3 REPLIES 3
allywhite666
416 Views, 3 Replies
This may sound like a stupid question with a simple answer so don't think me a bimbo for asking but how do I delete the AutoCad block symbols that are stored inside my drawing?
Not blocks that have been created that you can see on your drawing it’s the blocks that the point styles use and are stored in the drawing.
3 REPLIES 3
If they are used by a style definition I'm pretty sure you can't delete them. You would have to change the style to use a different block to be able to delete them.
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
troma
in reply to: allywhite666
I think the command you're looking for is PURGE.
But like Mike said, you can't purge them if they're in use. You first have to delete the style that's using them or tell it to use a different block.
Mark Green
Working on Civil 3D in Canada
rl_jackson
in reply to: troma
You might also try the Purge Styles command on the Manage Tab. This will purge the different sytles of all C3D objects
Rick Jackson
Survey CAD Technician VI
Rail Community
