Civil 3D Forum
AutoCAD Civil 3D won't launch after intalling
13 REPLIES 13
Message 1 of 14
2049 Views, 13 Replies
I installed the 2013 version onto my windows 7 64bit and after the installation process I launch the program and it freezes and then says there is an error. I have unistalled and reinstalled twice now with no luck. I attached a screen shot of what is going on. Any thoughts to help me get this running properly?
13 REPLIES 13
Message 2 of 14
Alfred.NESWADBA
welcome @forums.autodesk.com !
There seems to be some restrictions about the licensing-dialog or connection to internet.
Try to login to your workstation as administrator, disable firewall, disable antivirus, start C3D by right-clicking it and use option "start as administrator".
If that also does not help disconnect all network connections and try the same procedure again (so you will have to activate the product via mail).
Good luck, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 14
in reply to: Alfred.NESWADBA
the only thing that worked was disconnecting my network connection and now the 30 day trial has expired and when I reconnect the network connection to activate the product it has an error and closes the program.  You metioned activating the product via mail, how would I go about doing that?
Message 4 of 14
joane.bonghanoy
Hi mxduder,
To activate your Serial Number, click here or send me a Private Message (click on my joane.bonghanoy profile name and then “Send this user a private message”) with your Serial Number and Request Code
Joane Bonghanoy
Message 5 of 14
in reply to: joane.bonghanoy
I can not access my Request Code
Message 6 of 14
joane.bonghanoy
Hi mxduder,
What is the error message when trying to generate the Request Code? Do attach a screenshot of the error.
Joane Bonghanoy
Message 7 of 14
Alfred.NESWADBA
And you have tried the login as administrator? And the right-click onto the AutoCAD icon and use option "start as administrator"?
- alfred -
Alfred NESWADBA
Message 8 of 14
ive attached a screenshot
Message 9 of 14
Yes its my personal laptop so I am logged in as the adminstrator and I have right clicked and ran the program as administrator and it was working and running the program until the 30 day trial expired, now it will not let my activate it, it gives me the same error that I was having previously when trying to start the program
Message 10 of 14
We have had a couple of these come to us and we have found that if you update your Graphics Driver, then it will run. This has happened to at least 3 clients of ours and it has worked. See how you go it might help you as well.
Message 11 of 14
my graphics driver is up to date
Message 12 of 14
Alfred.NESWADBA
>>>there<<< may be a solution to that message, Also >>>that<<< thread handled a simiar issue.
HTH, - alfred -
Alfred NESWADBA
Message 13 of 14
Same problem
Brand new Lenovo P50, Fresh installation of Autodesk Infrastructure suite Premium 2013, all works except Civil 3D.
It gives  message " AutoCAD Application has stopped working" no error number, nothing ...dud aplyed patch C3D2013 x64_SP2.0 ..got success installation message, nothing chaned
Windows 7 64 Bit
All Drivers up to date
hardware meets all criterias
Ended up with uninstalling all junk from Lenovo
Clean, new windows with nothing on it
2 days of "gaming"...no result
Ouch!!!
Message 14 of 14
Alfred.NESWADBA
which of the above suggestions have you had tried?
- alfred -
Alfred NESWADBA
Rail Community
