Civil 3D Forum
AutoCAD Civil 3D and Cleanup Utilities
0 REPLIES 0
Message 1 of 1
subpartner
436 Views, 0 Replies
Hello All,
I have come across an issue whereby selecting subassemblies from toolpalettes in C3D 2012 either will not work (nothing happens when you click on them, the cursor does not change and there are no messages on the command line) or the program crashes. The only items from the tool palettes that will work are the turning heads. This is because they are blocks and not subassemblies i imagine.
The root of the problem appears to be a free 3rd party PC clean-up utility called Glary Utilities. After a fresh installation subassemblies work fine. When Glary Utilities is ran with default settings it results in the above issue. It appears that the clean-up removes a dll file associated with subassemblies.
The problem can be solved by clean uninstall and reinstall of C3D. I have tested with similar clean-up utility (CCleaner) and this appears not to cause any issues.
Has anybody had any similar experiences with clean-up utilities?
Donal McMoreland
HP Elitebook 8540W
8GB RAM
Windows 7 Pro 64bit
NVIDIA Quadro FX 880M
Using UKIE country kit
0 REPLIES 0
Rail Community
