Greetings.
I am trying to download AutoCAD Civil 3D on my new computer (Windows 8 64 bit) and I keep getting an error saying that the program failed to install. Need some help to solve the problem. Here it is the info it gives me.
2014/3/24:10:18:57 === Setup started on ===
2014/3/24:10:18:57 Path_Length: 152
2014/3/24:10:18:57 Current Directory C:\Autodesk\Autodesk_C3D_2014_English_Win_64bit_wi_en-us
2014/3/24:10:18:57 Launch
2014/3/24:10:18:57 CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/CIV3D/WI/Autodesk_C3D_2014_English_Win_64bit_wi_en-us_Setu... /SN 900-44516858 /PK 237F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/3/24:10:18:57 Setup Windows update reboot is pending
2014/3/24:10:19:18 Setup Autodesk AutoCAD Civil 3D 2014 Will restart automatically.
2014/3/24:10:19:18 === Setup ended ===
2014/3/24:10:26:59 === Setup started on CARY_VG by Carolyn ===
2014/3/24:10:26:59 Path_Length: 152
2014/3/24:10:26:59 Current Directory C:\Autodesk\Autodesk_C3D_2014_English_Win_64bit_wi_en-us
2014/3/24:10:26:59 Launch
2014/3/24:10:26:59 CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/CIV3D/WI/Autodesk_C3D_2014_English_Win_64bit_wi_en-us_Setu... /SN 900-44516858 /PK 237F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/3/24:10:26:59 Current Directory C:\Users\Carolyn\AppData\Local\Temp\_AI429.tmp
2014/3/24:10:27:17 === Setup ended ===
2014/3/24:10:27:06 === Setup started on ===
2014/3/24:10:27:06 Path_Length: 152
2014/3/24:10:27:06 Current Directory C:\Users\Carolyn\AppData\Local\Temp\_AI429.tmp
2014/3/24:10:27:06 Launch
2014/3/24:10:27:14 Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/CIV3D/WI/{3E4A5384-5B44-4DB1-BA1D-7FB5775F6DD7}/SETUP_x64....
2014/3/24:10:27:16 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Carolyn\AppData\Local\Temp\_AI429.tmp\Setup\AcSetup.dll
2014/3/24:10:27:16 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/3/24:10:27:17 PageOpen LaunchDialog
2014/3/24:10:27:28 PageOpen LicenseDialog
2014/3/24:10:27:28 PageOpen ProductSelectionDialog2
2014/3/24:10:27:42 PageOpen LicenseDialog
2014/3/24:10:27:42 PageOpen LaunchDialog
2014/3/24:10:27:53 PageOpen LicenseDialog
2014/3/24:10:27:53 PageOpen ProductInfoDialog
2014/3/24:10:27:53 PageOpen ProductSelectionDialog2
2014/3/24:10:28:06 PageOpen FullProgressDialog
2014/3/24:10:28:06 Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/CIV3D/WI/{3E4A5384-5B44-4DB1-BA1D-7FB5775F6DD7}/DIRECTX.ta...
2014/3/24:10:28:06 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD Civil 3D 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/3/24:10:28:25 Install DirectX Runtime Succeeded
2014/3/24:10:28:25 Installing FARO LS 5.1.0.30630 (64bit): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Civil 3D 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Civil 3D 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/24:10:28:40 Install FARO LS 5.1.0.30630 (64bit) Succeeded
2014/3/24:10:28:41 Download Skipped CM http://trial2.autodesk.com/SWDLDNET3/2014/CIV3D/WI/{3E4A5384-5B44-4DB1-BA1D-7FB5775F6DD7}/CM.tar.lzm...
2014/3/24:10:28:41 Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Civil 3D 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Civil 3D 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/24:10:29:36 Install Autodesk Material Library 2014 Succeeded
2014/3/24:10:29:36 Download Skipped CMILB http://trial2.autodesk.com/SWDLDNET3/2014/CIV3D/WI/{3E4A5384-5B44-4DB1-BA1D-7FB5775F6DD7}/CMILB.tar....
2014/3/24:10:29:36 Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Civil 3D 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Civil 3D 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/24:10:30:04 Install Autodesk Material Library 2014 - Base Image Library Succeeded
2014/3/24:10:30:04 Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD Civil 3D 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Civil 3D 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Civil 3D 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/24:10:30:18 Install Autodesk Content Service Succeeded
2014/3/24:10:30:18 Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Civil 3D 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Civil 3D 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/24:10:30:24 Install Autodesk Content Service Language Pack Succeeded
2014/3/24:10:30:24 Installing SQL Server CE 3.5 x86: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Civil 3D 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Civil 3D 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/24:10:30:34 Install SQL Server CE 3.5 x86 Succeeded
2014/3/24:10:30:34 Installing SQL Server CE 3.5 x64: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Civil 3D 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Civil 3D 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/24:10:30:41 Install SQL Server CE 3.5 x64 Succeeded
2014/3/24:10:30:42 Download Skipped VBPOWERPACK http://trial2.autodesk.com/SWDLDNET3/2014/CIV3D/WI/{3E4A5384-5B44-4DB1-BA1D-7FB5775F6DD7}/VBPOWERPAC...
2014/3/24:10:30:42 Installing Microsoft Visual Basic Power Packs 10.0: "C:\Autodesk\WI\Autodesk AutoCAD Civil 3D 2014\3rdParty\VBPowerPacks10\VisualBasicPowerPacksSetup.exe" /q /l C:\Users\Carolyn\AppData\Local\Temp\VisualBasicPowerPacks10Setup.log
2014/3/24:10:30:48 Install Microsoft Visual Basic Power Packs 10.0 Succeeded
2014/3/24:10:30:49 Download Play C3D http://trial2.autodesk.com/SWDLDNET3/2014/CIV3D/WI/{3E4A5384-5B44-4DB1-BA1D-7FB5775F6DD7}/C3D_x64.ta...
2014/3/24:10:42:11 Download Aborted C3D http://trial2.autodesk.com/SWDLDNET3/2014/CIV3D/WI/{3E4A5384-5B44-4DB1-BA1D-7FB5775F6DD7}/C3D_x64.ta...
2014/3/24:10:42:11 Install Autodesk AutoCAD Civil 3D 2014 Failed Download Failed, Installation aborted, Result=1603
2014/3/24:10:42:12 Rollback Microsoft Visual Basic Power Packs 10.0 Failed Failure is ignored, Result=1619
2014/3/24:10:42:18 Rollback SQL Server CE 3.5 x64 Succeeded
2014/3/24:10:42:22 Rollback SQL Server CE 3.5 x86 Succeeded
2014/3/24:10:42:32 Rollback Autodesk Content Service Language Pack Succeeded
2014/3/24:10:42:48 Rollback Autodesk Content Service Succeeded
2014/3/24:10:43:27 Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2014/3/24:10:44:16 Rollback Autodesk Material Library 2014 Succeeded
2014/3/24:10:44:19 Rollback FARO LS 5.1.0.30630 (64bit) Succeeded
2014/3/24:10:44:20 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
I will aprecciate any help. Thank You.
Hi
I have Dell Vostro 5468 just bought yesterday with Windows 10 Pro but for some reason I cant install AutoCAD Civil 3d. IF any one can help. I will really appreciate that. Many Thanks. Abdul Jamil
Hi @shinwara. Welcome to the forum.
We're going to need a lot more information. What version of Civil 3D? Where are you installing it from? What error message(s) are you getting. Additional specs on your Dell - RAM, Video card, HDD and/or SDD?
Allen Jessup
CAD Manager - Designer
The specification for my Dell Vostro are i5 processor, 8GB ram and 256GB solid state drive.
i get error 1619. i resored windows back to factory settings but it still did not work. i have never had such problem with autocad civil 3d before.
can you advise me what are the exact requirements for AutoCAD civil 3d ?
1619 is a Windows error. It would still be better to know the version of Civil and where you're installing it from. Requirements depend on version but I don't think that would prevent an install.
In the mean time. See if THIS helps.
Allen Jessup
