AutoCAD Civil 3D General
Valued Contributor
Message 21 of 28 (511 Views)
Re: AutoCAD Civil 3D ®2013 Service Pack. --> Please tell me one is due out so
11-29-2012 11:52 AM in reply to: pmascaro
Thanks, Wasn't sure what you meant by "commication center in Civil 3d" but I figured it out.
Paul R. Mascaro
CAD Supervisor | Engineering Design
ENVIRON International Corporation
System: Dell 6600M
OS | MS Windows 7 64-bit SP1
CPU | Intel Core i7 @ 2.70GHz
RAM | 8.00 GB DDR3 1600 MHz (Dual-Channel @ 798MHz)
Graphics | NVIDIA Quadro 5010M (4 Gig)
*Expert Elite*
DarrenP
Message 22 of 28 (510 Views)
11-29-2012 11:53 AM in reply to: pmascaro
it will be here when autodesk posts it to their website: http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9240698
Valued Contributor
Message 23 of 28 (497 Views)
11-29-2012 01:00 PM in reply to: pmascaro
1st bug to report....
It does not find acad2013.lsp and acad2013doc.lsp in my custom support path even though it is the highest path in my support path. Even when I remove them from their default locations, C3D will not find them in my support path. It just ignores them completely. I had to appload them in. (This will not be fun to support… Manual labor on everyone’s PC to get their computers to load the correct files…)
Paul R. Mascaro
System: Dell 6600M
*Expert Elite*
Jeff_M
Message 24 of 28 (489 Views)
11-29-2012 01:40 PM in reply to: pmascaro
You shouldn't be modifying those files in the first place.... acad.lsp and acaddoc.lsp are intended for users to create/edit, as these are never touched by installs/updates.
Distinguished Contributor
Message 25 of 28 (483 Views)
11-29-2012 01:53 PM in reply to: pmascaro
I wonder if that has to do with the feature they added to try to prevent the acad.lsp "virus" people have misunderstood.
My gripe to add is the hotfix 2 does not install silently. I think the install makers need a little checklist, it would go like this:
1) make it easy to do silent installs of every product, for ever and ever, from here on out.
2) do not forget rule No. 1
3) Our first impression of software is the install. At least get that part right by not forgetting rule No 2.
Valued Contributor
Message 26 of 28 (480 Views)
11-29-2012 02:02 PM in reply to: pmascaro
Yes, I would imagine In some places they are for the "users" to create/edit. In my office they are for me "The Supervisor" to edit. I use them to load custom applications, force variables, etc.
Rather than rely on everyone to overwrite their acad.lsp in all versions of their AutoCAD’s I release updates to C:\_AutoCAD\Config\lisp\
Then, regardless if someone is running C3D, Map 3D, AutoCAD, they all point to that location to pull from the master acad.lsp and acaddoc.lsp
If I add a new command for the department, all I have to do is add it to their .net folder and add the line to load it into their acad2013.doc.lsp file. Then it’s there next time the open a drawing….
I definitely do not want them tinkering in there….
I’ll try dropping the 2013 from the file to see if it works…
Paul R. Mascaro
System: Dell 6600M
Message 27 of 28 (477 Views)
11-29-2012 02:17 PM in reply to: pmascaro
I never heard the acad.lsp and acaddoc.lsp were more for users of not.
I know the acad2013.lsp is present in an OOTB install, and I thought was not for customization.
We also use one acad.lsp and acaddoc.lsp for each version of acad, and I also have a company key-ins file that works for all versions (2009-2013) and also for bricscad.
The trick is to make your own load function that detects what version and prog you are in, and selects the file to load from an input list.
Valued Contributor
Message 28 of 28 (474 Views)
11-29-2012 02:23 PM in reply to: pmascaro
Dropping the 2013 seems to have worked.... although I do not see acaddoc.lsp in my appload menu, but the function in there seem to be working....
Paul R. Mascaro
System: Dell 6600M
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
