AutoCAD Civil 3D General
areawest
Message 1 of 22 (429 Views)
AutoCAD Civil 3D 2013 Question
429 Views, 21 Replies
03-18-2013 09:06 AM
I reloaded Civil 3D 2013 to try an resolve some issues I was having with error messages and the program taking for ever to load.  When I first redownloaded the software and installed, it was fine.  Now, two days later, I am having the same problem as before.  I get error messages saying that I am missing shape files and semantic errors in the DCL file.  When the program filanlly opens, about half, if not more, of the widgets in the ribbons are clouds with question marks.  Any suggestions?
troma
Message 2 of 22 (411 Views)
Re: AutoCAD Civil 3D 2013 Question
03-18-2013 10:31 AM in reply to: areawest
Maybe ask in the installation forum.
Credit where credit is due! Give kudos or accept as solution whenever you can.
wfberry
Message 3 of 22 (407 Views)
03-18-2013 10:42 AM in reply to: areawest
Did you completely remove the previous installation per:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20304823&linkID=9240697
Bill
areawest
Message 4 of 22 (396 Views)
03-18-2013 10:51 AM in reply to: wfberry
Bill,
I followed the steps to completely remove 2013, but I did not remove 2010 or LDD.
wfberry
Message 5 of 22 (334 Views)
03-19-2013 09:43 AM in reply to: areawest
I don't think it is necessary to remove the other products.  However, you may need to run a repair of your installation on the others if you have problems with them.
Bill
areawest
Message 6 of 22 (331 Views)
03-19-2013 09:48 AM in reply to: areawest
Bill,
I spoke with a install tech yesterday and they took over my computer and ran the repair.  For some reason, a bunch of the CUI files didn't transfer in the install process.  They got it to work correctly, but when I opened the program today, same issue.  It is driving me nuts.
Jeff_M
Message 7 of 22 (323 Views)
03-19-2013 10:11 AM in reply to: areawest
Are you using the correct shortcuts? It sounds like your Support paths are getting reset/removed/not used.
rkmcswain
Message 8 of 22 (321 Views)
03-19-2013 10:13 AM in reply to: areawest
Did you allow the new install to "migrate" your files?
areawest
Message 9 of 22 (315 Views)
03-19-2013 10:20 AM in reply to: areawest
Jeff and RK,
I used the default settings and didn't change anything.  Looking in the explorer, all the CUI files that were reloaded when the tech repaired Civil 3D yesterday, are gone today?  The only difference between today and yesterday is I turned off my laptop yesterday evening, and back on this morning.
rkmcswain
Message 10 of 22 (304 Views)
03-19-2013 10:37 AM in reply to: areawest
There is no default. It will ask you if you want to migrate settings from an earlier version, and you can accept or decline.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
