Hi all,
I'm pleased to be able to announce that this updated extension for Civil 3D
2011 is now available on Subscription Center for all Civil 3D Subscription
customers.
New features are:
· Support for Civil 3D 2011 both 32-bit and 64-bit
· Support to import data directly from the Bentley MXROAD binary
'modelfile'
Full details below and on Subscription Center
http://subscription.autodesk.com
AutoCAD Civil 3D 2011 Import/Export Extension for GENIO
Release Date: 2010-05-11
The AutoCAD® Civil 3D® 2011 Import/Export Extension for GENIO streamlines
the migration of data from Bentley® MXROAD® software to AutoCAD Civil 3D
software. It also enables customers to use AutoCAD Civil 3D on projects that
require Bentley MXROAD format deliverables and/or the use GENIO or binary
"modelfile" format as data sources. Capabilities include:
· Import Bentley MXROAD alignments, profiles, surfaces, points and
feature strings into AutoCAD Civil 3D;
· Export AutoCAD Civil 3D model elements including points,
alignments, profiles, corridor feature lines, and grading feature lines into
the Bentley MXROAD format.
This extension is compatible with the 32-bit and 64-bit versions of AutoCAD
Civil 3D 2011. Content is currently available in English only, but will
install on all language versions of AutoCAD Civil 3D.
Ian McGregor
Industry Solution Manager
