I can't attach a subassembly. I create an assembly baseline, open subassembly tool palette and click on any subassembly, but nothing happens. If I drag the sub assembly into model space it looks like an i-drop icon, but it does not attach to the assembly. I can copy an existing sub assembly and attach it to the assembly, but can't attach one from the tool palette. I've done a repair and it did not solve the problem. I've tried this in 2011 and 2012 and it does the same thing.
Could it be a problem with Norton blocking access to the catalog? If so, how do I fix it? I've disabled Norton firewall and antivirus and still had the same issue.
The problem is that when I select the subassembly, there is not a prompt on the command line to choose the assembly.
When you click on a subassembly does it show that it is executing the "CreateSubAssemblyTool" next to the command line? Are you getting any error messages or does Event Viewer show anything?
I am seeing various forum post that talk about having problems with subassemblies, and they all seem to relate to the subassembly path not be setup correctly somehow.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Subassemblies-are-pointed-to-wrong-path/m-p/2710343
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Subassembly-Error/m-p/3036526/highlight/true#M153092
When I click on the subassembly in the tool palette, nothing happens. Nothing on the command line or in the event viewer and no errors. I can copy an existing subassembly and attach it to an assembly, but I can't retrieve one from the tool palette. I'll investigate the links you sent.
Thanks, Steve.
