Hi
I have a problem with point codes in section views in civil3d 2013. They are not showing at all. Drawing was made in civil3d 2012 and all point codes with defined styles were displayed correctly in section views and now they are all gone. Just link codes are shown. Is there something in setup of code styles that has to be changed?
Even if i set up new code and new label style it does not show up in section view after rebuild. Just in assembly.
If i do the same for link label it does show both in assembly and in section views.
I would suggest that you upload a data set for one of us to look at. It's really hard to troubleshoot an issue like this just from a post. My first inclination would be to suggest that the code set assigned to your sections is different than your assembly, having the dataset would help, as it sounds like your very familiar with them.
