AutoCAD Civil 3D General Discussion
millsy.g
Message 1 of 5 (498 Views)
Assembly for divided highway with inconsistent offsets
498 Views, 4 Replies
11-05-2013 11:11 AM
What I have is a highway that is being twinned, however the divided lanes are not consistantly the same distance away (or the same width of roadtop). I would like to keep the number of alignments to a minimum. Both lanes would be based off the same vertical profile. So I would like to have a single assembly that could adjust the median width in the center, and the lane width. Targetting the horizontal layout you can see in the attached screenshot. (this is not all of the job of course)
Is this a feasible task for the targetting assemblys?  Would be a fairly standard 4:1 side slopes, adjustable ditch bottom width, 2% crowned road otherwise.Twinning.PNG
Valued Mentor
fcernst
Message 2 of 5 (484 Views)
Re: Assembly for divided highway with inconsistent offsets
11-05-2013 12:22 PM in reply to: millsy.g
I see you will need to be able to push your Median across your centerline for your left turn lanes. A common request.
We used to be able to do this, but now this mainstream design capability is broken in the latest release of the software due to poor quality control.
If you have a project deadline and need to keep moving forward with this, you may want to highly consider Bentley software.
Please see the following threads for more information.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Confirmed-Defect-Medians/m-p/4380944
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/C3D-2014-SP1-Medians-Still-Not-Working/td-p/4...
Fred Ernst, PE
C3D 2015
Ernst Engineering
www.ernstengineering.com
millsy.g
Message 3 of 5 (474 Views)
11-05-2013 12:30 PM in reply to: fcernst
Technically I could move my centerline to keep it in the exact center of both roads, and not have to cross the median at all.
What I'm more interested in, is the changing distance from the centerline, and trying to use a horizontal target for the crown.
*Expert Elite*
sboon
Message 4 of 5 (439 Views)
11-05-2013 10:26 PM in reply to: millsy.g
A few questions:
  • Do you have two lanes of existing roadway or is this going to be all new pavement?
  • Are you adding new lanes to one side or both?
  • Raised or depressed median?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Valued Mentor
fcernst
Message 5 of 5 (388 Views)
11-06-2013 04:44 PM in reply to: millsy.g
..Technically I could move my centerline to keep it in the exact center of both roads, and not have to cross the median at all...
Yes, if you can do that, the Civil 3D median workflow is very dynamic and powerful, especially if you implement Offset Alignments.
I just quickly whipped up an example for you below in the first image with my raised median assembly.
We have lost the ability in 2014 though, to execute Case 3 shown in the second image below. Pushing the median across centerline.
This is very frustrating and worrisome as we need this capability to create our Left Turn lanes.
I wish Peter Funk would get this pushed through repair immediately. This is project critical design capabilty.
Come on Peter...
Fred Ernst, PE
C3D 2015
Ernst Engineering
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
