AutoCAD Civil 3D General
Active Member
ejfancett
Message 1 of 6 (446 Views)
Assembly Style Marker
446 Views, 5 Replies
10-31-2012 07:18 PM
Anyone know how to turn off the yellow flags.  See the attachment photo.  I click on them and the whole assembly is lit. I am at a loss.  What am I missing?
Any help will be appreciated.
EJ
Message 2 of 6 (439 Views)
Re: Assembly Style Marker
10-31-2012 08:28 PM in reply to: ejfancett
That is part of the LaneSuperElevationAOR subassembly, no need to remove it.  The potential pivot property controls it.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
Valued Contributor
wizengr
Message 3 of 6 (414 Views)
11-01-2012 11:19 AM in reply to: mathewk
I thought the flags can be turned off by opening the Properties Palette, selecting the Assembly and then setting the "Potetial Pivot" option in the Tool Palette to "No".
Message 4 of 6 (412 Views)
11-01-2012 11:20 AM in reply to: wizengr
Yes, that's what I meant in my comment [...The potential pivot property controls it....]
Matt Kolberg
Active Member
ejfancett
Message 5 of 6 (382 Views)
11-02-2012 09:25 AM in reply to: ejfancett
Thanks!  It is on the subassembly properties.  I should of checked there, but since it lit up with the assembly I was confused.
Valued Contributor
Grimes_MG
Message 6 of 6 (58 Views)
02-28-2014 10:32 AM in reply to: ejfancett
How would you not display and/or not plot the "Potential Pivot" object if your road need one? I am using the assembly as a "typical cross section" in a drawing and the PP object is plotting.
Win7 (x64), EVGA 790i, 8GB RAM, EVGA 8800GT, 250 GB iSSHDD, & RAID 0/1
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
