Anyone know how to turn off the yellow flags. See the attachment photo. I click on them and the whole assembly is lit. I am at a loss. What am I missing?
Any help will be appreciated.
EJ
Solved by mathewkol. Go to Solution.
That is part of the LaneSuperElevationAOR subassembly, no need to remove it. The potential pivot property controls it.
I thought the flags can be turned off by opening the Properties Palette, selecting the Assembly and then setting the "Potetial Pivot" option in the Tool Palette to "No".
Yes, that's what I meant in my comment [...The potential pivot property controls it....]
Thanks! It is on the subassembly properties. I should of checked there, but since it lit up with the assembly I was confused.
How would you not display and/or not plot the "Potential Pivot" object if your road need one? I am using the assembly as a "typical cross section" in a drawing and the PP object is plotting.
