Dear Members,
I have a difficulty in assembly as shown in attached Image. In Cross-section specially at superelevated section assembly get distorted. Please guide me for this condition..
Thanking You....
Welcome to the forum!
1) What specifically do you believe is wrong about it? You've shown what it looks like -- a sketch of what you think it SHOULD look like would help.
2) Are you using a custom subassembly or stock?
3) What version are you using?
Don Ireland
Engineering Design Technician
Thanks for giving attention.....
1. Cross-section of road at perticular regions gets distorted at centre, the continuation of layers is not achieved at superelevation regions.
2. I have used Subassembly- Lane outside super layer varying width form the subassembly tool pallets.
3. I am using autocad CIVIL 3D-2012.
Here I am posting screenshot of actual assembly which is used.....
Thanks.....
Hello!
I think problem not in Subassembly, but in design decision. How must located asphalt under dividing line you think?
Sorry for my English..
It appears that you've created a median which is always flat, so that the two inside curbs are always at the same elevation. The gravel structure under the curbs rotates to match the superelevation, so the inside edges don't line up. You could modify the assembly to create a flat road structure under the median, or you could change things so that the median and the two curbs rotate together with the rest of the roadway.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
