AutoCAD Civil 3D General
Active Member
CADSonny
Message 1 of 7 (182 Views)
Assembly Help - (C3D newbie)
182 Views, 6 Replies
02-03-2012 11:02 AM
Ive been given the task to design a corridor with the following assembly, the oroblem is I'm not getting the assembly to work, I've tried using conditional cut and fills and also daylight subassemblies but am having no luck. The right side should only have a fill after the berm at 1.5:1 and the left should only have cut at 10:1 with an 8m berm and then 10:1 to surface. I'm not too familiar with subassemblies but ideally would like one where I could use select cut or fill but can't seem to find one that works. I've attached an image for reference, if anyone could give me some suggestions I would appreciate it.
*Expert Elite*
sboon
Message 2 of 7 (174 Views)
Re: Assembly Help - (C3D newbie)
02-03-2012 11:15 AM in reply to: CADSonny
I would suggest that you check the help file for DaylightGeneral.  It's quite a complicated sub, which usually scares people away, but it will definitely be able to do what you want.
Active Member
CADSonny
Message 3 of 7 (153 Views)
02-03-2012 12:51 PM in reply to: sboon
I'm not having much luck with this either to be honest, is there any way of making a daylight just do cut or fill?
*Expert Elite*
sboon
Message 4 of 7 (148 Views)
02-03-2012 12:55 PM in reply to: CADSonny
First you need to tell us which version of the program you're using.  Otherwise the answers posted may not be useful for you - that's why people add the info to their signatures.
Active Member
CADSonny
Message 5 of 7 (138 Views)
02-03-2012 01:19 PM in reply to: sboon
Autodesk Civil 3D 2011
*Expert Elite*
sboon
Message 6 of 7 (126 Views)
02-03-2012 01:50 PM in reply to: CADSonny
OK this should do what you asked for.
Active Member
CADSonny
Message 7 of 7 (121 Views)
02-03-2012 02:05 PM in reply to: sboon
Wow!, thanks a lot I really appreciate it :smileyhappy:
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
