I've got a corridor created, the profile done and the assemblies created. I've attched the assemblies to the regions & they are shown when I view/edit the corridor sections, but when I plot the sections they're not plotted.
It worked before on another small job that I was using to teach myself C3D, but I just can't figure out what's going on here. I've looked at the section styles, the corridor styles & the assemblies themselves, but I can't find anything.
Solved by mathewkol. Go to Solution.
If your corridor exists, but it is not in your section views, here are some things that can be wrong.
Thanks for your help.
1) I can see them & pick them when I view/edit corridor sections, but they don't plot.
2) I've sampled the existing surface & the finished surface. I take it that's what you mean by sampling the corridor?
3) I've thawed & turned on all the layers, so that's not it.
4) I don't understand what you mean here. I let C3D (I'm using 2011) create the sample lines.
Sorry to tag along to this tread but I have a similar problem. Some of my assemblies are only showing on certain stations. If I view the stations on the cross section editor, the corridor looks just fine, but when I go to the section sheet where the corridor is x-referenced, the driveway disappears.
I have rebuilt the corridor numerous times, detached and reattached the drawing, made a new drawing and recreated the sample lines to no avail. Attached are some pictures to show the disappearing driveway on the right side of the street.
Any suggestions are welcomed.
