AutoCAD Civil 3D General Discussion
New Member
vmorales
Message 1 of 3 (167 Views)
Accepted Solution
Assemblies/Corridors
167 Views, 2 Replies
11-01-2013 09:01 AM
I am trying to create a corridor which would use the lip of curb existing elevations on both sides of the road.
I'm not sure where exactly I would target these points.
Would I do this in the assembly or the corridor?
The subassembly I used was LaneOutsideSuperLayerVaryingWidth, but it asks me for a slope.
I want the slope to depend on the existing elevations at lip of curb.
I'm new to Civil3d, only been using it about a year. Currently 2014.
I'm sure it's something simple.
Thanks for the help in advance.
Active Contributor
hmartinez5
Message 2 of 3 (145 Views)
Re: Assemblies/Corridors
11-01-2013 11:12 AM in reply to: vmorales
If the distance from your alignment to the lip of curb is constant, simply create a "Surface Profile" from the alignment and make that profile the elevation target in the corridor parameters.
If the distance is irregular, create an additional alignment which follows the lip of curb. Create a "Surface Profile" from the additional alignment and use as the elevation target in the corridor parameter.
New Member
vmorales
Message 3 of 3 (132 Views)
11-01-2013 12:45 PM in reply to: vmorales
That worked. Thanks!
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
