I am in a hurry and can't fool around with the array command....
I want to make parking strips on the outside of a curve... I cannot remember how to do this, its been 5 years since...
what process do I go through??
I always do parking space markings by making a block of the pavement marking and then using the MEASURE command and using the pavement marking block at the required spacing.
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
If you're in Civil 3D 2012 take 1 min and mess around with the new "Path" option on array. If you are doing parking along a curve this is pretty cool. After you layout the parking, mess with the curve and watch the lines update.
Cheers,
Peter Funk
